BUSHWACKER 20935-02 15-17 F150 78.9 AND 67.1 AND 97.6 FT. BED AND WILL NOT WORK W AND TECH PACKAGE AND STYLESIDE FENDER
Pocket Style Front and Rear Fender Flares (20935-02) by Bushwacker 4 Pieces Set. Tire Coverage: 1.5 Front 1.5 Rear. Flare Height: 6.125 Front 7 Rear. OE Matte Black. Replace your OEM fenders with the hardcore pocket-style debris protectors and give your vehicle that aggressive rugged appearance you were looking for. Specifically designed for moderate and extreme wheel and tire the upgrade is a perfect all-in-one solution for all off-roaders.
Features- 15-17 F150 78.9 & 67.1 & 97.6 ft. Bed & Will Not Work W & Tech & Styleside Fender
- Extended tire coverage to reflect road debris
- Specifically designed for mid- and large-sized wheel and tire combos
- Made from Dura-Flex 2000 plastic for ultra strength and durability
- 100% UV-protected to prevent sun damage
- Can be painted to match your vehicle's color
Price: 758.82
